I recently bought a Spec R.C. (current model black/lime 29er). This is a second/backup MTB bike generally used for trail/rough rocky trail. I noticed right off that there was significant bearing grind in both hubs (Shimano HB-TX505 fr and FH-TX505 rear). I've had dozens of bikes throughout lifetime never saw/heard it that bad in a new bike?! Dealer (Bikeway/Wappingers, NY) said nothing was wrong...maybe needed a little grease?! Second mechanic said they were little tight...and adjusted. Still noisy/grinding. Basically all said these are "okay"?! At any rate. I am looking to buy a another set of wheels (non-carbon) to replace these soon. They are 29er QRs 9x100/28h fr and 9x135/32h back. Center lock disc Shimano. As this is a second bike I'm not looking to break the bank here in the replacement - just want to find something dependable and already built up maybe lighter that will retrofit easily. 3-$500 range maybe. Looking for some advice from some that maybe have done similar or have recommendations. I'm road rider primarily and not familiar with some of the mtb brands like Stans etc. etc.
Fork. The OEM SR Suntour XCM 29 is pretty lousy and would like to upgrade this to a Rockshox/air or similar. Again, nothing that will break the bank. The frame is Medium size - and think the travel is 90mm? If someone has done a retrofit recently and has suggestions they would be appreciated. I saw post from some time ago - and the user replaced with something no longer available.
Any help or recommendations appreciated.
