For some reason today I started thinking about the rear shock, suspension and pivots. I need a little help understanding the correct terms and functions. I searched for quite a while for an 'exploded view', schematic or diagram of the rear suspension of a specialized bike (my focus is on the 2012 stumpy), but I think almost any of their air/oil shocks would work. I looked at Fox as well.
I think I have figured out that the shock typically has 'eyes' at either end (mine has only one and splits into a yoke around the seat tube on the wheel side).
I believe the eye has a 'DU Bushing' which I think is a friction reducing bushing and is intended to be replaced every so often? I think next there is a 'reducer' that sizes down the hole that has a shaft or spindle to attach to the frame. Is the close to correct?
Sepcialized states 'sealed cartridge bearing pivots' for the pivot points. What were they before? Just a shaft or bushing?
Every once-and-a-while I see something about swaping out for needle bearings. I am imaging this would be for the lower eye on the typical rear shock? Do I have this right?
Lastly, can anyone find a diagram, schematic or exploded view of a stumpy rear shock and pivots???
