Replace the bent hanger first. Adjust your high limit screw. Refer to this video.
Thanks. I have tried the adjustments. It is not the limit screw. I'll try again tomorrow with the new hanger and let you know. But I clearly see that there is a big side position difference between the jockey wheel and the front chain ring. Hope hanger will resolve the problem.Replace the bent hanger first. Adjust your high limit screw. Refer to this video.
It will make a difference, a bent hanger is the worst cause of shifting woes. 😝Thanks. I have tried the adjustments. It is not the limit screw. I'll try again tomorrow with the new hanger and let you know. But I clearly see that there is a big side position difference between the jockey wheel and the front chain ring. Hope hanger will resolve the problem.
Unless the jockey wheel is way out of alignment with the cog, doesn't sound likely that the hanger is going to do much.I'll try again tomorrow with the new hanger and let you know. But I clearly see that there is a big side position difference between the jockey wheel and the front chain ring. Hope hanger will resolve the problem.
Hi AllEvery multi speed kid's bikes I've ever worked on had a bent hanger. Sounds like it is bent inwards towards the rear of the bike.
