1 - 10 of 10 Posts
All-in-all, they ought to fit up. Only thing that may be of issue would be the steer length(highly unlikely, but still could pose an issue) and BB shell width.
Although... I hope you aren't expecting those parts to last too long....
Meh.
You'll need a different headset and a different seatpost and clamp. And you'll probably want to convert the rear wheel to a bolt-on. And of course you'll have to SS it (well, you could use a Saint derailleur or one of those dropout derailleur hanger doo-hickeys).
Bikes Rule
As mentioned you will need a new post, clamp ( frame does not come with it), headset and maybe a new rear wheel if you have a Q/R. Most Specializeds use a 30.9 post and the riot is a 27.2. Also need an integrated 45/45 contact angle Campy style headset.
For the cranks it depends on the set-up you have. If you have 3 rings, take off the inner and middle. See of the BB will work with the cranks. Not sure what you have on there but you may also need new cranks...
Head tube is pretty short and you use an integrated headset so you should be OK there...
1 - 10 of 10 Posts
