21 - 40 of 114 Posts
Now broadcasting from CO
TurnerConvert said:
Actually, if it were an XT cassette, that would be OK. The one spec'd on the website is the HG81, which best as I can tell is an SLX-grade cassette. That said, upgrading any one of those parts isn't too expensive. And honestly, they all perform reasonably well. Whereas, having the stock rear hub be such a low quality component is really not acceptable since having the rear hub fail doesn't just mean buying a new rear hub, but having the entire rear wheel rebuilt as well. :madman:
True... but since most of us who want race wheels can't afford the rovals, I think a lot of people are going to end up ditching the stock hub and rebuilding with another 142x12 hub so we don't have to deal with adjustments every time we swap wheels.
On another note, someone should start collecting the hubs when people pull them off then send a shipping crate full of them back to specialized... it would be kinda funny...
Just what I was thinking! They may get the point.?
Discussion Starter · #23 ·
To all of you that are complaining about less than optimal parts coming on your bike, remember that it's ALL ABOUT PRICE POINT. I can see it from both ends since I own an Expert EVO R 29er and am a Specialized dealer. I got my bike today and just finished taking off the parts that I am not going to use:
wheels
cassette
seatpost
saddle
stem
These will all be replaced with lighter parts and the ones I like and trust and will give me the best performace, durability, and weight. Specialized could have put better parts on their Expert level bikes, but the price would go up. Then customers would complain about high MSRP. Remember, This is not just a Specialized thing either. I had a $5700.00 Cervelo that came with a $300.00 wheel set. In today's market, product manufacturers are picking the best parts for a given price point. If you want all the best parts them spring for the S-Works, but don't complain about the high price tag. Remember, you get what you pay for.
Discussion Starter · #25 ·
WR304 said:
If you get the 26" 2011 S-Works Epic then you still have to replace the wheels, even with the high price tag.:eekster:
http://forums.mtbr.com/showpost.php?p=7674742&postcount=29
I'm not sure what your point is. You are quoting a conversation about Stumpjumper FSR not EPIC. The wheels that come on the S-Works Epic are incredible whhels! Unfortunately, I.m nt sure they would hold up in the long run under my 200 lbs. I ended up going for Industry Nine XC29 wheels. They should hold up as a dual purpose race/training wheel and give me great performance. Plus the will have a huge bling factor!:thumbsup:
Sorry, the post was #29 from this thread discussing the wheels of the 2011 26" S-Works Epic.:)
http://forums.mtbr.com/showthread.php?t=662755
The point being that the wheels on the 2011 26" S-Works Epic aren't top of the range. They feature alloy Roval rims instead of the carbon fibre Roval rims. The alloy Roval wheels on the 2011 26" S-Works Epic also weigh more than the alloy Roval Control SL wheels which came on the 2009 and 2010 26" S-Works Epic.
If you truly want the lightest top of the range 26" Roval carbon fibre wheels for your 2011 26" S-Works Epic then you have to buy them seperately because they're not standard. :)
http://www.specialized.com/us/en/bc/SBCEqProduct.jsp?spid=57939
Discussion Starter · #27 ·
Good point, but the "get what you pay for" still holds true. If the Rovals with carbon rims were on the bike, then the price would be higher. You see it many times in the idustry that bikes are down speced from the previous year. This is so there is not as much sticker shock when you see the prices on the new model. Some times inflation climbs quicker than what the product managers think the market will bear. That is when you see down specs. It does not mean you are getting less value. Margins on any retail product have to be at a certain level for a business to sustain itself. If you want to complain about prices, then complain about the economy in general. Just don't do it on a mountain bike forum.;)
I agree with that. I was just pointing out that even the 2011 S-Works bikes aren't immune from cost cutting as they don't necessarily have the best parts as standard.:)
herothedog said:
I'm converting a Hope II hub for the 142+ through axle. I'm told this is going to work, but can't say if it is or not. I have some doubts from some photos I have seen.
Don't confuse the nomenclature. You're converting a Hope II hub for the X-12 142 through axle. Hope doesn't build a 142+ compatible hub. The "+" being the differentiation here.
As for the corner cutting on Specialized's part, I have the Epic S-Works 29er and they advertise it as having XX chainrings. It doesn't.
As for the carbon wheels. I'm not worried about them holding up under me and I'm a 200+ lber.
Specialized definitely needs to step up with an EL level wheel like they specced on the Marathon 29er last year with the DT compatible hub and the "+" spacing.
Yes on specialized.com it does say that in the "features" but then again it doesn't in the "technical specifications" and the picture of the bike.
Can't hurt to call specialized and say something about it.
Yup. Just pointing it out as an example that they even cost cut on their S-Works models. Granted, SRAM doesn't make a XX chain ring set in the ratio that's been specced for the S-Works 29er.
Lafawnduh said:
Lots of talk about the stock wheels and hubs that come on the Specialized epic 29er. I believe all the models except the S-works is equiped with the same set up. I am not a expert but I think if your spokes are correctly tensioned and relieved the hoops and spokes should give resonalbe service. (don't trust the factory build) The rear hub may need more attention in order to get good longjevity out of it. I took it apart and this is what I found
This is what the axel looks like. It spins on two cartrige bearings
Once you removed the two 17mm lock nuts on the freehub side, did you have to tap or hammer the axle out? Or remove another locking nut somewhere?
I can remove the two locknuts on the free hub side but the axle won't come out. I have lightly tapped on the axel but don't want to start hammering unless I am sure there are no other lock nuts to be removed.
Thanks!!!
erichwic said:
Yeah, the S-Works are still cutting corners since the frameset comes with the stock "HI-Lo" rear hub. According to my digital scale it weighs 364 grams and has shotty engagement.
Non of the S-Works Epics come with the Joytech hub. If it's either the 26 with the Alloy rimed roval wheel or the 29 with carbon wheel they both have the guts of the DT star ratchet hubs like the 240.
bikeguyO, I used a wooden mallet to tap the drive side after the nuts are removed. I believe you are doing it correct, you just need to hit it harder. The drive side bearing is more difficult. Let me know if you need help with that one. I don’t know the recommended way to remove it but what I did was quite simple. When you have the bearings out pull off the seals and re-grease. The stock grease looked very weak.
I built up a set of XTR hubs for my epic (142+rear) on Stans Crest Rims. I may be looking to sell them though because I want black nipples and these guys have red ones, (petty I know). They have been great and a def improvement over the Epic Expert 29er stock build! Let me know if anyone is interested!
matt3542 I'd be interested in those wheels. What do you think you want for them? How many miles so far?
Let's fly!
jrob1775 said:
Yeah same here:madman:
I was hoping to get away with the stock wheelset for one season, then upgrade next year when there are more options for 142. With all the talk about these wheels being heavy, weak, and having poor engagement, I'm starting to rethink that strategy.:eek:
Does anyone want to buy a stock wheelset...REAL CHEAP???:D
See below for my experience with the stock hubs. I pretty much only rode gravel roads for the first two months I had the bike because the trails were all snowed in. After a couple of "real" rides, the engagement got even worse than stock (hard to imagine, I know), but only on an intermittent basis. After a couple more rides, there were some funny sounds coming from the rear hub. Took the cassette off and a few large pieces dropped to the floor and a whole lot of ball bearings fell out. Massive disappointment! I as already planning to get new wheels to remedy the engagement issue, but I was shocked to find the thing fell apart within a few hundred miles of easy riding.
I replaced mine with Industry 9s with Arch rims. Love'em!! Highly recommend them! And they fit on easily, just a minor adjustment to the derailleur and I've been pedaling happily ever since. :thumbsup:
I decided to go with I9s (standard 12x142 instead of Specialized's proprietary 142+) instead of Roval Carbons so I don't feel locked into Specialized for my next bike. I really, really like my Specialized Epic Expert 29er, but it's probably not the last bike I will ever buy. The next bike could very well be a Specialized, but maybe not. I decided I9s were more portable to the next bike. The I9s are very modular and configurable, so I see them as an investment that will last for many years, from one bike to the next.
Anyone know if there is a way to convert the stock 142+ wheel back to a normal 135 rear hub?
Like many others, I replaced my Specialized wheels and now they are just sitting around. They probably have very little resale, so it would be great if I could at least convert is an use the wheels on my singlespeed or something.
