I just ordered a 2011 Specialized Epic 29er Expert EVO R and understand that the stock Formula hub is not very good (poor engagement and heavy).
I intend to build up a race wheelset and use the stock one for training. Here's where the problem comes in. Since Specialized uses their own 142+ which places the cassette 2mm farther out on the hub, I don't want to adjust the rear der. when I switch back and forth. Has anyone withe the new Epic come up with a solution to this? Can you space the cassette farther out on an aftermarket hub to match the 142+? The only soution that I can come up with is to spring for the high end Rovals which I really don't want to do since I am a bigger guy and am worried about durability. They are also a lot of $$$
Thanks in advance for the advice,:thumbsup:
Jeff
Jeff
