1 - 10 of 10 Posts
Discussion Starter #1
Hi,
is possible change the original Front Derailleur Shimano in my next Scott Spark 910 with Sram ?
type S1 or S3 ?
thanks
Beppe
Italy
Discussion Starter #3
thanks pumaking,
i want mounting rings 36-22 ,but the original front derailleur Shimano is for ring 38-26.
bthen, i buy SRAM
Hi,
I have a problem to fix FD-M952 e-type to my Spark 30 2012. In the adapting plate the hole are in different distance then in the derailleur. Do you know the solution?
Discussion Starter #5
confirm,serving the direct mount s3.
i think no good for press fit BB92 mounting one e-type,and the hole is different :(
in my Spark 910 2013,change the shimano original with Sram S3 for ring 36,,,perfect!!
I want FD as a direct mount so I disassemble the carbon plate from derailleur. The problem is with the holes.
Has the standard changed in the mean time?
Are different adapting plates from Scott?
1 - 10 of 10 Posts
