Status
Not open for further replies.
1 - 1 of 1 Posts
https://classifieds.mtbr.com/showproduct.php?product=21534&cat=7
2008 Transition Blindside size large. This frame has been used lightly and is in great condition. It has frame savers in most wear areas so cable rub is very minimal. It does have a few scratches here and there but none of them are major.
The bike comes with the rest of the sticker pack shown, seat clamp, and green anodized bearing caps. The frame comes with stock cable clips to secure shift and brake cables instead of zip ties.
Price is $1200 plus $60 shipping in the US.
Payment is preferably via Money Order but can also do Google Checkout which can process credit cards.
Specs and Features:
205mm - 8 inches Rear Wheel Travel
Fox DHX 5.0 Coil 8.75 x 2.75 stroke
6000 Series Heat Treated Aluminum
Frame Weight: 8.6 lbs (without rear shock)
1.5 inch headtube
Compatible with up to 8 inch dual crown forks
12 x 135mm thru axle Dropouts
73mm bottom bracket spacing
Accepts up to 8 inch Rear Disc Brake Rotors
Easily fits up to 2.8 inch rear tire
Front Derailleur Compatible with E-Type Derailleur
Seatpost: 30.0mm
Seat Clamp: 34.9mm
Disc Brake Mount: International Standard
Standard ISCG Mounting Tabs
1 - 1 of 1 Posts
Status
