Not with enough BTUsAlso, what is the size and insulation of your garage? Those things matter.
Essentially why I use 80K BTU to heat 800sqft. haha.Not with enough BTUs.
Oversized 2-car. Cars are never in itAlso, what is the size and insulation of your garage? Those things matter.
This looks stand alone, right? no plug in, just make sure it has fuel and fire it up?![]()
Dyna-Glo 50K-80K BTU Convection Propane Tower Portable Heater RMC-LPC80DG - The Home Depot
The Dyna-Glo 50K-80K BTU Propane Convection Heater is ideal for outdoor/indoor construction, as well as industrial & commercial applications, making it an excellent choice for your portable heating needs.www.homedepot.com
You connect it to a 20lb tank with included 10' hose. You could probably get away with using the smaller one:This looks stand alone, right? no plug in, just make sure it has fuel and fire it up?
I wouldn't run a propane heater in my house, but I don't consider my garage inside my house. With the air leaks around the roll up doors, I've never had a low oxygen issue. If you are concerned about that, you could always life your garage door slightly to vent in some fresh air.the electric infrared quartz heaters work pretty well. They tend to heat surfaces rather than the air, so they don't work as well in an empty room but you'll "feel" the heat more. you're limited to about 1500 watts on a 120V outlet, but even that will make a noticeable impact on your electric bill if you run it a lot!
propane might be the way to go, I just never like burning anything indoors.
Carbon monoxide kills silently!Not electric, but I use a 80K BTU propane mushroom heater in my 800sqft garage. Heats it up right quick. Not the most efficient if you are going to use it constantly, but for the few times I'm out there and have to work on a car or my bikes, it easily makes it T Shirt weather.
