1 - 18 of 18 Posts
My "rfx rocker" search yielded some pretty ambiguous threads. Might as well just ask and get flamed if need be. Was pondering last night if anyone has ever machined out the stocker 06 rfx rockers? I think they just look bland. That is all.
What? Never owned a Mongoose in my life, you got me confused with Vinny?
I like Turners. Come in here to check things out. Been eyeballing a DHR but it won't happen cause I don't have that kind of loot. Somehow I managed to just pick up a new Yeti DJ frame though.
You got Bennet's BB mount Gamut backplate in your possession? I am going to need it for the DJ build up. Got any 31.8 bars for sale? Gonna need one of them too.
Banned
Have you thought about polishing them? I've seen threads with polished rockers and they look good. I don't know about machining holes in them though. They are much thinner than the newer generation ('07-'08) rockers.
Mr Tiles said:
yeah, I mistook you for vinny - bwahaha
you are a closet bike whore
no bars and bendit has your gamut guide.
This thread is out of control ;-)
I am lot taller and don't break everything I ride.
Only reason I am not a bike whore is cause I don't have the money.
I will e-mail him
PASA Style!!! Derail in three posts or less.
I got a nice Dremel you can borrow.
Discussion Starter · #8 ·
It's crossed my mind but the swing arm is polished so I thought for a bit it might be a little over the top. ball burnished might be sweet though.
This is the kind of info I'm looking for. I don't want to eff 'em up. I have access to a machine shop with a laser table and before I went nuts, I wanted to know any dangers of removing material. I'm purely speculating that rigidity of the rockers needs to be vertical more than lateral and removing material from the already machined surfaces won't cause a detriment. I'm not an engineer so I'm trying to cover all the bases before I cause some destruction.
Banned
I remember a few people who dremeled a small indent in those rockers in order to mount the air shocks of that time. There were subsequently quite a few failures if I recall. They didn't remove even a fraction of the material that you plan to. Although, that was a pretty high stress area (just behind the shock mounting hole--non-drive side). My original '06 plates have the dremeled appendage, and I have not had any problems. It's a tough call, but I'd say no way.
You could get them plated.
Discussion Starter · #10 ·
I also thought about just having a set made. A custom design merely for bike snobish reasons, absolutely no performance advantage other than a slight reduction in weight. Fashion over function...
I take it PUSH never made a set of rfx plates?
Elitest thrill junkie
Like this?
Lay off the Levers
I Endo Rando did some interesting polishing of his spot and rockers,
You may want to consider something similar:
1 - 18 of 18 Posts
