rail a berm
Berm: a dirt bank on the outside of a turn. It prevents you from sliding, so you can go much faster.
Rail: you go around that turn like on rails.
technical
One definition: Trail features like rocks, roots, steeps, drops, etc. make the trail demanding enough that your speed is not determined by how hard you can pedal, but by how you cope with the obstacles. This is obviously subjective.
gnarly
Pretty technical, possibly with some danger thrown in.
g-out
You go down something steep and then it levels out suddenly. The G forces push you towards the ground, compressing the suspension... or you might even collapse onto the bike.
switchback
Very tight turn, usually going up or down a hill that is too step to do without zig-zagging.
tuck the front end
technical vs. non-technical trail
See technical above. On non technical trails you don't have a lot of obstacles that slow you down or otherwise demand much attention.
flickable = easy to throw around, manuverable, nimble
Roughly yes.
pedal kick back
Rear suspension action is felt through chain-cranks-pedals.
brake jacking
Using the brakes makes rear suspension rise.
technical
gnarly
g-out
switchback
tuck the front end
Roughly yes.
pedal kick back
brake jacking
