It is steel drum. It measures tire compression hysteresis loss. It does not measure losses created by the interaction between the tread and the ground. In my experience, *warning speculation* it is best applied to dry conditions, because the tires that test well do feel fast to me. In wet conditions, knob shape and height affects drag losses more as they push in and are sucked out.Does anyone know whether these are steel drum tests? Because in my experience, these don't translate well to the trail where the compliance of the tire matters. Take the Race King - it killed it in the test. And yet, I have been consistently slower on this tire on a rooty loop that I have ridden dozens and dozens of times. It has been slower than Fast Traks, XR1s, Michelin Force XC, and Aspen.
Theoretically, yes. It is indoor with lab equipment. May not translate well to the real world. I generally found them to be OK. Tires such as the old Nevegal were >50 watts and felt exactly like that.So the higher the watt# the slower the tire?
Disappointing to hear that about the Maxxis, I once had some Kenda Honey Badgers that I really liked but thorns punctured them super easily and the tread wore out in a fraction of the time that any other Maxxis I have ever owned. I was hoping to try out the Hellkat and hoped that it lasted longer.Kenda rubber still wears out pretty stupidly fast. 500 miles and a day at a bike park reduces the legendary Hellkat grip to something that feels more akin to an entry level tire.
e13 TRS *race* definitely feels a level slower out of everything I've tried.
I still stick to Maxxis for value for money. Can get 3k miles out of a Maxxis tire (HR2, DHR2, Ikon), if it doesn't fail in some other way. The rubber compound is just too good, and EXO is borderline tough enough (SnakeSkin and Kenda ATC are way to flimsy for me).
Scwhalbes seem to run lighter than other tire brands too though and the only tire I have ever destroyed on a trail was the Nobby Nic, so I am concerned that they are also more fragile. I have been curious about throwing a Hans Dampf on my bike but have good luck with Maxxis so I am concerned about switching brands.It reiterates what I've noticed when I test tires, that the Schwalbe's tend to roll faster than every other tire due to the compound.
Sent from my SM-G892A using Tapatalk
All the bontrager tires say 39.99 euro which I am pretty sure means they didn't test the team issue versions. You know, the version that 95% of mtbr readers would use.Interesting that the XR3 rolls faster than the XR2.
My wife and I have and like RaceKing and I wonder if the feeling slow times comes from just not having a lot of off road traction. With those and MSO 50s in similar bikes I notice the RaceKings just can't corder as fast and slip where the MSO 50s can have traction.Does anyone know whether these are steel drum tests? Because in my experience, these don't translate well to the trail where the compliance of the tire matters. Take the Race King - it killed it in the test. And yet, I have been consistently slower on this tire on a rooty loop that I have ridden dozens and dozens of times. It has been slower than Fast Traks, XR1s, Michelin Force XC, and Aspen.
They listed them as Team Issue on the subsequent pages.All the bontrager tires say 39.99 euro which I am pretty sure means they didn't test the team issue versions. You know, the version that 95% of mtbr readers would use.
Sent from my Pixel 3 XL using Tapatalk
