Hi, I was reading an earlier post about someone trying to put a Gusset 1-er conversion kit onto a King hub. Shiggy said it was not good because the narrow based cog will ruin the FH.
I used the Gusset kit on a Hope Bulb disk hub, but I only used the spacers. Actually, I had to use one Shimano spacer closest to the flange, then the widest spacer (Gusset), a 16 tooth shimano cog of an old cassette, the smaller spacer (Gusset), then the Gusset lockring. Works for now with a Singleator, but will this ruin my hub? I didn't use the Gusset cogs cause they wouldn't work with the 9 spd chain I was using. Will this setup using an old Shimano cog and Gusset spacers ruin my hub?
Is the narrow base of the cog referring to the amount/width of the cog that actually makes contact w/the FH? If I do end up buying a better cog (Surly) will I still be able to use the spacers from the Gusset kit (will the Surly cog be too wide when used with the spacers) or did I just waste some money? Or will the Surly cog be wide enough in which I don't have to use the small Shimano spacer? Bottom line is, I want this too work with the Gusset spacers (if possible), get a better cog, and I don't want to ruin my Hope Bulb. Thanks in advance for any help.
