Just got one of those new Tange-Prestige steel Somas. I am in the middle of the buildup and when placing the rear wheel which has a DT Swiss 240 hub, the distance between the dropouts is a full 5-6mm too narrow for the rear wheel to fit. It will fit but only after I spread the tubes apart. The dropouts clear the rotor by only about 1-2mm.
Forgive me, but this is my first build. Is this normal and the rear fork tubing will just conform to the distance of the rear hub or is the frame messed up and requires either re-welding or whatever? Kind of frustrated about this since the buildup was going pretty well up until that.
Any help would be greatly appreciated. Thanks guys.
