either swap cranks or shift to the 22 ring. outboard cranks ahve 49-51mm chain line. the best you will find in a modern crank is around 47.5 or so
Is the inside plate of the front derailleur close enough to the chain to prevent it from dropping down? This a crapshoot suggestion, becauise in theory nothing at this end has changed. But it may be worth your time to reset your front derailleur, ensuring that your inside plate is a gnat's ass off the chain when you're in the 22x34 combo, with the cable unattached.redmr2_man said:The front D isn't touching the chain at all in that gear combo, not even a hair...so that can't be the case.
Makes sense. Time is money. If the price of a new chainring is worth less than 2 minutes of your time, go for it. But I'd venture that it takes more time to replace a chainring, than to re-camber the existing one. If you were in NY I'd offer to race.redmr2_man said:Honestly because it just sounds easier to replace the ring. They aren't too expensive, and time is money my friend!
I DO appreciate the tips though.
Oh, jeez, how did I miss that little tidbit of info?kapusta said:...an issue of the new chain...
