You need to find a new shop. That's one of the easiest things they should be able to do.czryan said:Does anyone know if it is a hassle to convert an older LX hub ('98?) to a solid axle? It has stumped my LBS. Thanks!
I just switched my deore hub to a solid axle this week and it is really simple. I found an axle at an LBS for $3 and just followed the directions at the park tool site. Just make sure you replace everything in the correct order.czryan said:Does anyone know if it is a hassle to convert an older LX hub ('98?) to a solid axle? It has stumped my LBS. Thanks!
Yeah, you most definately need a new LBS.czryan said:Does anyone know if it is a hassle to convert an older LX hub ('98?) to a solid axle? It has stumped my LBS. Thanks!
