1 - 1 of 1 Posts
The frame was built up 9/19, has had regular pivot/bearing maintenance and has just been completely checked over and greased. The Fox DPS shock was swapped out when new so has 0 hours and has a RWC roller bearing at the linkage. There are a few chips and scratches on the rear triangle and the area under the seatstay yoke had a small gouge by a rock stuck in the tire but has had a professional repair and I repainted the area myself as you can see in the pictures. The paint at the bottom shock mount bolt chipped when I replaced the washer with a bigger one because the stock one was distorting. Otherwise the frame is in excellent condition and comes with a headset w/new bearings, a One-up 150 mm dropper and a spare derailleur hanger. Price is firm!
1 - 1 of 1 Posts
