I think you scale is off, or you got an very light set, as mine weigh 611 for the crankarms and preload bolt. But yeah, they're about the same weight as XT.
Nope, triple ring version.Flystagg said:Is yours the version with the steel pedal inserts perhaps?
It is. Replacing it with one from XT saves about 30g IIRC.ginsu2k said:Is the granny ring on the SLX steel? It looks like it is because it is drilled out and usually manufacturers don't drill out Aluminum rings.
