My wife's bike is set up with an 11-52 chinese 11-speed wonder, courtesy of ZTTO excellent warranty policy
It was being shifted with an 11 speed SLX shifter and RD-M6000-GS Deore rear derailleur. It kind of worked, but was far from 'click->shift' kind of performance. I mean - I can get around a little lazy shifting from time to time, but for the life of me - my wife just expects digital performance. One of those days I'll get her an electronic shifting and set it to 'auto'.
Anyhow. The issue is that Deore derailleur was not meant for 41T spread of the cassette. So with the introduction of the shimano 12 speed I toyed with the idea of getting an SLX 7100 rear mech and try to run it on 11 speed drivetrain.
Read: it took me approximately 20 seconds to order one, when it became available. It arrived in a few days, and this happend:
TL: DW:
- 12 speed shimano uses the same dyna-sys pull ratio as their 11 and 10 speed lines. Mix/match as much as you desire.
- the mech is pretty agnostic when it comes to the cassette - it will work with just about anything you throw at it as long as you ride 1xX. I tried with 11-23, 11-40 and 11-52. With this derailleur you can utilize those 10 speed massive range chinese cassettes with no issues.
Now this got me thinking. Since mix/match is now a thing. You can get reliable shifting with shimano 12 speed offerings with:
12 speed cassette -> match to 12 speed shimano mtb shifter
11 speed cassette -> match to 11 speed shimano mtb shifter
10 speed cassette -> match to 10 or 11 speed shimano mtb shifter
Since DynaSys is kind of compatible with old sram ESP, then
9 speed cassette -> match to 9 speed SRAM ESP shifter
8 speed cassette -> match to 8 speed SRAM ESP shifter
Now. It appears that sram 12 speed shifters are compatible with shimano, so the following should also work. But I have no gear to check it:
12 speed cassette -> match to 12 speed SRAM 1x shifter
TL: DW:
