1 - 20 of 21 Posts
· Registered
Whenever people describe jumps and trails, they usually give a measured description of a drop... like "Dude, we went down an eight-foot drop!" I go to the same trail thinking that I have to fall the height of Yao Ming's extended hands only to see a ledge not much higher than my chest (and I am officially in gnome territory in terms of height).
Maybe I'm wrong, but how are drops measured? Is it the delta between the highest point of the launch to the wheel's point of contact? Or in instances where the trail drops off considerably, would it be the bottom? Or am I just plain off my understanding? I tend to think that a drop requires some airborne time with the bike.
· Registered
The correct way to measure the size of a drop is from the lip to the top of the transition/landing. If you were to measure a drop base upon the amount of distance your bike has dropped, then you are no longer measuring the drop. Instead you are measuring the distance your bike has dropped. Usual mistake we hear is people saying " I just did a 8 foot drop!" when they actually just did a 3 foot drop with a steep transition.
A better way to look at it is that a 3 foot drop has a minimum of 3 foot of drop for the bike, but with more speed it can easily turn into 8 foot of drop for the bike.
· Content from my avatar
CactusJackSlade said:
And indeed with the new math 2+2 does equal 5... as long as you feel good about it ;) :D
And as long as Big Brother says so! :rolleyes:
I don't measure drops. The only thing I care about is if I clean it and if I can go bigger or smoother off it next time.
· I just wanna go fast!
he's pretty much right.
Some people feel the need to measure the distance of the diagonal rather than the vertical to make themselves feel better. That's just silly.
When it comes to riding with your buddies, I've found that the best way to communicate is "small drop", "big drop", and "Scary big drop".
When it comes to reading about it on the internet, I've found the best way is "pics or it didn't happen". :D
· Registered
You generally measure a drop by the vertical distance from the height of the take off to where your rear wheel touches down. If you are going to label a drop as being a set height drop i'd probably say do it by the amount of vertical free-fall you have for a normal amount of speed taken off of the drop. The problem you are running into though is more about people exaggerating how big drops are.
· Registered
I thought I got to DH forum :)
Anyway, Pinkbike rule is from the lip to landing zone (so everyone is claiming whatever they feel like)
MTBR rule is from the lip to the closest ground as if you do slow speed wheelie drop and amount you flew over tranny doesn't matter. This way there is no ambiguity.
For instance rolling bump is just what it is and not a drop. If you hit it hard you may fly some distance and even loose elevation if it's downhill, but it's not a drop regardless.
Small drops with long tranny you can pre-test and go bigger gradually but drop difficulty remains the same. Big drop you have to commit for minimal clearing amount. So think about drop size as a minimum commitment level to hit it ;)
· Custom User Title
I define "drop" as a trail feature I can not roll down without both wheels leaving ground. I generally avoid those on a mountain bike. I have a little BMX to play, though I am not good at that either.
I measure drops by placing them in two categories: "mkey" and "f-it".
1 - 20 of 21 Posts
