Ok, I pretty much know what I think I like in MTB geometry at this point, but the snow bike might be a bit different...
Top of my ponderings is the fork. I think I'll be running a 70.5 degree head angle. I don't want the bike wandering all over the place at low speed on technical winter singletrack. I also don't want a twitchy bike at the moderate (~20-25 mph tops, probably) top speeds it will see (ice and twitchy don't play well together).
I'm thinking I want to rake the fork out quite a bit more than is typical of production endomorph-capable snow bike forks. This has me worried. Why does the typical fat bike run so much trail? I figure trail on the low end of normal will be livable at speeds of 5-25 mph or so, and minimal trail will reduce the thrust wobble that happens in very low speed maneuvering around obstacles on the local (highly technical, even in winter when the snow isn't very deep) singletrack. I also wonder if there isn't some pneumatic trail at speed due to the drag on the big, low pressure tire that will help more at high speeds than it hurts at low speeds....
Thoughts?
Thoughts?
