Just thought I'd post up my ride here... already put up a few pics in the "Show off..." thread, but it seems the urban/dj/park forum could use some more activity.
Well, It's no custom mini-boutique bike, I didn't weld it myself, and no pink or chrome bling, or the hottest mtb parts to hit the market (although I did manage to basically color coordinate while still using parts I had on hand or selecting ones I wanted....)
Anyway, I've been riding it for just over a month now, working out the kinks, adjusting, modifying, etc., and so far, it's coming out better than I expected. I wheeled off, and ground down the cable stops, since I don't use a rear derailleur, and I'm debating doing the same to the V-brake mounts, and grinding off the ends of the dropouts, just to lose some weight and make it look a bit smoother. I took off the gyro stops, since I don't use one and went with a longer brake cable.
chainstays are locked down at 15.5", tt is 22" c2c, bb height is 11.3", wb is 39.625", bar height is 37.75".
a few more photos:
almost forgot....
here's the spec list:
Eastern reject frame
Marz DJII 06'
FSA Impact Pro integrated headset
Atomlab GI Dirt 24" rims in dark grey
Atomlab GI 20mm hub front
Eastern Bikes 14mm X 135mm Singlespeed disc cassette hub and 12t driver
Demolition tensioner (drive-side only)
DMR Moto RT front
Kenda Kiniption rear (really nice)
WeThePeople Royal 175 cranks in grey & euro 19mm bb
Animal lite V2 28t sprocket
Shadow Conspiracy Interlok V2 chain
Animal Steven Hamilton Pedals
Demolition F-1 bmx stem
Atomlab Jesme Cig 22.2 bars - cut down to 24.5"
Animal Edwin DeLaRosa grips & cheap plastic barends that will hopefully last the season
Avid BB7 mech disc caliper - slightly modified to be bolted more forward
Hayes 6" rotor
Tektro cheap lever, custom bent lever blade
derailleur cable housing for brake
Macneil post w/ custom guiness aluminum can shim
Macneil SL kevlar saddle
Coalition seat clamp
custom ground frame, eliminate cable hangers, round off dropout ends, etc...
let's hear what you think...
a few more photos:
almost forgot....
Marz DJII 06'
DMR Moto RT front
Hayes 6" rotor
