Last night I installed my new SLX cranks. Installation went a-ok until I tried to remove the outer ring and replace it with my bash guard. I grabbed my trusty 5mm hex wrench and noticed it did not fit? Huh. No worries, the 4mm fit. I successfully removed 3 of the 4 chainring bolts but that 4th one was stuck good. After I cranked down on it, I heard it pop loose - or so I thought. I popped it a couple more times and finally noticed that it was not loosening at all, it was stripping the bolt head! Upon closer investigation, I see that they are NOT hex heads, they are TORX. WTF!?! Since when and why the switch?? :madman:
The T25 spun freely now, it was so stripped. I was finally able to remove it by hammering in a T30, which gave enough bite to loosen the bolt. Since that bolt was destroyed, I replaced them all with the 5mm hex bolts from my old set. Anyway, bashguard is now on and Im ready to roll. Just thought I would pass along the warning.
