1 - 8 of 8 Posts
I just bought a El Mariachi 2
It came with a slx 2x10 crankset.
I'd like to convert this into a single speed, not a 1x10.
do I use the inner ring or the outer ring for this?
can I buy any 104 bcd chainring?
Is it cheaper/easier to just buy a ss crankset?
Discussion Starter · #3 ·
I understand chainline, but it seems that 64 bcd is hard to come by for single speed chainrings.
any recommendations?
By "inner" or "outer" you meant "small" or "big" chainring. Everybody else meant whether or not you place the ring on the inside or outside of the spider. Obviously you should replace the "big" ring with a single speed chainring. On a triple crankset you can run the chainring on either side and that gives you a little bit of chainline adjustability. I'm not sure if that's possible on a double. If it isn't, just run the new ring where the old one was.
Using an SLX as SS too. Use any SS 104BCD ring, and double check you have the correct size ring bolts. I made that mistake once on a Sunday evening and the wait for the LBS on Monday was grueling!
1 - 8 of 8 Posts
