You love your 180mm & Saint setup, why change?
Oh, I am just curious if I can get away running new 7/6" rotors on the Saints without the rear feeling like not enough power out back cause I do use the rear brakes a lot for scrubbing speed when coming in hot on corners and turns (without skidding of course due to awesome modulation and power control of Shimano brakes, whereas my Avids in the past (Elixirs) would have a tendency to lock up some and skid). Just a lilttle torn cause I like just a bit more power up front if possible (without having to go up a whole rotor size to a 8") to do most of the braking and don't want to buy a fairly expensive new Shimano rotor to see if I don't like it or doesn't work.PissedOffCil said:You love your 180mm & Saint setup, why change?
