1 - 12 of 12 Posts
I have a set of formula 24. The front lever doesnt return to the extended position unless I push it out. I noticed that when I gave the extra push the pads were also retracting. I assumed it was a "sticky piston". So I extended the pistons out a bit, cleaned with alcohol as well as possible, then added a bit of lite lube around the piston. I then cycled the pistons with pads and rotor a number of times, thinking this would loosen it up. No go. Still slow return.
I also lubed the pivot on the arm.
Any ideas on what should be tried next?
thanks.
Have you tried removing the cable and cable housings from the bike and and spraying a cleaner/lube into the housing. Your prob. could be a "build-up" of "gunk" inside the housings. If you've tried the ends, try the middle.
Discussion Starter · #5 ·
I just rebled them.
I heard from a LBS that sometime the lever adjuster rubs on the inside of the lever. I screwed the lever adjuster all the way in, in fact too far in and stripped it. I think I really screwed it up, because it won't adjust back now. I'll call formula on Monday and see if they have any ideas on how to fix both problems now. Luckily I have a set of back up Hayes.
thanks for input.
ride hard take risks
chumbacabra said:
I just rebled them.
thanks for input.
Shoot them off a email tonight ya never know you may get a weekend answer. :thumbsup:
Discussion Starter · #9 ·
I ended up sending the brake into formula. They replaced the piston (?) or master selenoid (?). Whatever they did, worked well. Ended up costing me 53.00$. They also fixed the lever pivot. If you give them a call, they tell you. They've always been super helpful. Good Luck.
thanks,
Larry
Thanks Larry, I found out that this is a typical issue of older generation Oro brakes.
At the moment the "sticky" feel is at the initial phase, the lever simply isnt't as "snappy" as it used to be. It will probably get worse over time... then a master cylinder rebuild will be on order
thanks
fab
thanks
fab
I have a set of brand new Oro Puros and I've been having the exact same problem ever since I got them. The front seems ok, but the rear has always had poor lever return or none at all. Last time I lubed the piston and that helped somewhat--lever return was slow, but at least it worked. This time, no such luck. I have to push the lever back out manually to keep my brakes from continually rubbing. It's pretty frustrating. After spending good money on top of the line brakes, and hardly ridden them, I'm not too thrilled at the prospect of having to send them back and wait who knows how long to get them fixed. In the meantime, thankfully I have my other bike to ride otherwise I'd really be pissed. :mad:
Unfortunately I have found out it's a relatively common problem. However I lubricated the pistons and the sticky feeling improved a little bit.
Consider that the spare master cilynder "cartridge" is pretty cheap - but it's not an excuse for a poorly engieered part on a top-dollars brake system!
1 - 12 of 12 Posts
