Slight play in bb pivot
951 Views 4 Replies 4 Participants Last post by  Caveman Lawyer
I just recently purchased an XL Burner from Supergo and built it up about 3 weeks ago. After 11 rides, I can't say enough about this bike. I went on a four hour ride yesterday involving some serious climbs and technical downhill and the bike ate it up. More importantly, I felt like I could have ridden for another four hours.
Anyway to the point - when I pick up the bike a feel a slight klunking. It seems that the rear triangle drops a bit and there is a bit of vertical play in the pivot. The bike has the Manitou swinger 3, if that makes any difference. Anyone else have this problem? What can be done to fix it?
1 - 5 of 5 Posts
17 ft lbs on all main pivot bolts per Turner.
See this thread for more chat and specs:
http://forums.mtbr.com/showthread.php?postid=262017
Glad your enjoying it! Good luck!
I find the easiest way to pinpoint play is to put one foot on the rear tire to hold the back wheel on the ground, with one hand lift up and push down on the seat gently, and with the free hand go from one pivot to the next and put your fingers around the o-ring area and you should be able to detect where the movement is. One more thing to do is put the left crank arm parallel to the left chainstay, and using firm pressure squeeze the crank arm and chainstay together, and then spread them apart. If there is play in the main pivot, you should be able to see it. This is the best test to diagnose main pivot play.
Typically what you are describing is play in the shock mounts which is a reducer/bushing interface problem. If you can elminiate this possibility, but can't pinpoint the feeling, get the bike good and wet and try to work some water into the pivot o-ring interface. Do the lift/push thing and see if you can get a bubble to emerge/disappear at an oring. Also make sure your rear hub bearings don't have play (King hubs loosen up after break in and have to be readjusted).
Check the torque on all the pivots as was mentioned. After you have the issue pinpointed or continue to be stumped, report back. It is possible a part is out of spec, but I would suspect another cause first.
I had to get this spacer shimano makes for king rear ISO hubs to take up the slack between the cassette and the hub splines stop. If this is happening, you won't notice the clunk unless you are riding, then it's a LOUD clanking noise....pretty hard to miss. Good tip on the crankarm test - also may want to try to shake/move the rear wheel side to side and see/hear if you detect any binding/clunks in the pivots.
Sounds like your top shock mount is loose, though......
Great advice
Thanks to all for the great advice. It turns out it was the shock pivot mounts, specifically the lower one. However, they were both loose. Once tightened, the clunking went away. I appreciate the advice and links to the appropriate torque discussions. Funny how dead-on you both were...
1 - 5 of 5 Posts
