1 - 20 of 158 Posts
I was just wondering what your favorite slicks are for mountain bike commuing and also all these guys reporting 5 mph gains just by switching from the big knobbies, could this be a result of changing the tire diameter and not recalibrating the speedometer?
I'm SUCH a square....
2nd question first: Swapping from big knobbies to small slicks will make your speedo read faster than you are actually going, so going the same speed will read faster.
1st question: true slicks -- Specialized Fat Boys, 26x1.25; commuters -- Kenda Kwest, 26x1.5, or Intense Micro Knobby, 26X2.25, depending on your needs. I run the Intense's.
Double-metric mtb man
If you are looking for real speed (after adjusting the computer), I don't think there are many out there that can beat the Ritchie Tom Slick. They are a full slick capable of running at high pressure (provided your rims will take it) and have some pretty thin sizes (I've got a set of 26x1.4" that I can run at the 85psi max listed on the sidewall). D
on't get near gravel with 'em, but for roadie-tizing a mtb for commuting, I don't know if there is much better out there.
I've also used the Tioga City Slicker and Bontrager Hard Case (some side knobs, but heavy for serious puncture resistance). Our local police run the Hard Cases and they seem to hold up pretty well.
viva la v-brakes!
I prefer something slightly larger and more durable for commuting. Look for a tire in the 1.5-1.75 range that is designed to be puncture resistance. The skinny tires tend to loose air and pinch flat really easily, plus the bigger tires have a more comfortable ride. My old favorite were continental top touring if you can find those, the new continental street tires, the "Contact" series looks good but I haven't tried them. My LBS is totally sold on the Panaracer UrbanMax. I will be taking a maiden voyage on them today.
Slicked down MTB'muter
I like the 26X1.40 Michelin XC Road and I commute almost daily 19-miles one way. It is more efficient than knobbies as I was commuting on those for a few months. But a 5-MPH gain... maybe over a few months of building some endurance or maybe it's the excitement of having the smoove rollers... i don't know as I do not have a computer on my bike.
I just ride...
I will be putting knobbies back on at some point as I have some side trials I need to explore. Need to stay in ADV-MTB'muter mode, but i'm in recovery right now after breaking my neck in a off-road MX accident: KTM950 - BIG OFF & HOT NEW LOOK - Turkey Day 2007
Riding is a lot easier for sure... I didn't pick up 5mph average but I did pick up about a 2mph average (thats calculated distance over time) on my normal 7.46 mile training route. 11.1mph -> 13mph.
My commute isn't log enough to really notice much of a difference other than being able to roll in high gear a lot easier for a lot longer.
Geax Roadsters
Decent traction on loose stuff too - just found their limit the other day pushing too hard into a rutted gravel corner - minor front skid (no fall though)
ONe less gear
slicks are the way to go
I don't have a computer yet, so I don't know about the speed increase. But, I know I power through my tallest gear a lot easier with the slicks. I did a 30 mile commute today and chased a roadie for a long time. I think I made him angry though.
My wheels are at 95psi and the rim allows 113psi and the Maxxis Detonators go up to 100psi.
viva la v-brakes!
Also bear in mind that the smaller wheel diameter with small slicks will have you in higher gears, not to mention the fact that your on pavement which is a faster surface then dirt.
Peddle Faster Smoother Quciker Longer....
I agree - you will spin in a higher gear and I could actually use a larger front chain-ring. Need like a 52 to replace the 48, so yea, I must be peddling faster....
Bontrager makes a full slick in a 26 x 1.5
Michelin makes a commuter tire in 26 x 1.8
Both run right around 20 dollars.
As far as speed goes both of these tires will roll faster (less resistance). they are lighter than a knobby tire as well and as stated above you are riding on a smooth surface. So imo it is possible to gain an extra 5mph.
BIG and Bald
Full on slicks make me nervous so I run a tire that has a tread pattern even on my 700c wheels. For a 26" tire, I'm partial to the Specialized Crossroads or Hemispheres, both are 1.95's. If you want a narrower tire, check out the Nimbus or the Borough CX which are 1.5's.
MTB'muter Slicked Down
The Michelin XC Roads are 26X1.40 and top out at 87-psi. Not too fat and not too skinny!
I'm lacing up some "vintage" never used XTR hubs on some MAVIC 121 rims so I can try the Panaracer Urban Max that is 26X1.25 that max at 100-psi.
No photo yet.
I make sure that I keep my tires aired to the max limit for less rolling resistance - more efficiency. "FREE HORSEPOWER!" I also found that the Michelin's loose about 5-psi a week so keep a check on them.
MTB Addict
Schwalbe Big Apple 2.0
Fat enough that it doesn't look stupid, rolls great, corners beautifully, and, even at 60psi (max is 70, but with the wide slicks, I don't trust my rims), they don't ride too rough.
Schwalbe Big Apple 29'ers 2.35
FWIW I also ran 700x32 Michelin Dynamics
Good thing spesh gave the stumpy sliding drop outs because I could barely slide a credit card between the tire and the front derailleur.
I noticed a speed increase with the dynamics ( yes recalibrated speedo) shaving time off of a 3 mile ride by an average of 3.5 minutes.
With the Big Apples I do notice the mass these are I think said to weigh in at 990g + but once rolling I get the same speeds, times etc.. as I did on the 32mm Dynamics.
The major difference is that they are far more stable and all around useful, I can hop into a trail, go whizzing off the shoulder into rough gravel etc.... even ran them down an unmaintained road full of wash outs and fist sized rock areas at full speed.
I'm running Michelin Country Rock tires on my commuter. They're 1.5" and air up to 72psi. They seem to work great on pavement, tho I haven't tried a full slick to compare them too. That'll be my next upgrade, probably put a full slick in the rear and keep the treads up front.
I want some tread, as my commute can/will hit some single track on the way home. If I go to full slicks I'll have to stay on the road.
Card-carrying wotmeister
It's a little unorthodox but I commuted two miles to school and back every day on 2.1" Panaracer Fire XCs. While they're full knobby they roll nice and fast, they're a good tire to check out if you want the best of both worlds :thumbsup:
Nah...I'm currently running Rampages and they roll a lot faster than my XC's ever did.
1 - 20 of 158 Posts
