1 - 5 of 5 Posts
· Registered
Hi
Bought the taurine frame,SL Lefty,Integrated Steerer,SLR Wheels and I was about to fit my XTR groupset when the thought struck me - should I fit the SL crank?
The frame has the bb fitting for the XTR not the SL
Help please with these questions:
Is it possible to get my LBS to take out the bb and fit the SL?
Is it worth the hassle?
Which SL crank should I look for if it is?
How do you remove the threaded bb?
Thanks in anticipation
Steve
· FIRENZE rulez !!
yes it's possible
but Cannondale wrote don't do it , avoid warranty
but .... everything is possible
so , only take care of frame , the adapter is only pressed into frame and firmed with loctite
removal is easy ... but to do with care
on cannondale web site you can find pdf file wih instuctions , in tech notes
· FIRENZE rulez !!
yes it's possible
1 - 5 of 5 Posts
