Shift into middle chainring and one of middle cogs on back. Look from back of bike and make sure the the upper derailleur pully is DIRECTLY underneath the gear. Center of pully should line up right in center of gear you are in. If not turn barrel adjusters and try riding again after you make adjustment. Sounds like you may be off slightly and it is easy fix. If that doesn't work, can be something more serious, bad cassette, stretched chain, etc.Slugger said:
