I really want to try a coil shock in the back, but the space in my frame is very limited. The problem is clearance to the seat tube. The frame takes a 185x55 trunnion shock.
Which shock uses the smallest diameter coils? So far all I know is that DVO springs are supposed to be 53.30mm OD according to their support. Anything smaller than that? Also, the more distance between the lower bushing and the spring collar, the better. I printed out a DVO Jade to scale on paper and "installed it" in the frame, I think it MIGHT just fit. 😁
What if I used an offset bushing turned sideways to gain a tiny bit of clearance? Would that impact the kinematics a lot, or would it even work at all, or would the bushing rotate on it's own?
I know all of this might seem really stupid, i'm just super curious about coil shocks (and want to try just a new shock in general), but I don't want to buy a new frame yet.
