Been working on a project bike and thought I would share it. Running 1x10 w/11-36 XX cassette and 30t Extralite chainring. Bike is at 27.0 lbs as it sits.
The fork is an SBC/RS Reba S29 with carbon crown/steerer from the epic 29er, converted to 120mm travel, the wheels are stock Roval Control 29ers with oversized 28mm endcaps that are drilled out for a DT RWS. The shock normally gets swapped back and forth between the triad and the brain.jut8 said:That is an impressive weight, especially when you consider he has the command post on there! I want to hear more about the fork and the wheels. No brain shock? I'm surprised.
It's mounted off the BB cupjut8 said:Is the MRP mounted on the DMD front derailleur mount?
i think the poster works for the big S.xbrian said:How'd you get that color option? Frame only? did you get the comp and have it painted?
Yup, its works just fine.m-dub said:Does 10speed work with any 9 speed front ss ring?
