Can I use my dt swiss 240s hub as a single speed setup? Is it just a matter of buying a fixed gear for the rear hub?
Terminology is everything. If your freehub body is aluminum, make sure the cog you buy has a thick (~5mm) base at the splines to keep it from cutting into the softer metal.backtocali said:Can I use my dt swiss 240s hub as a single speed setup? Is it just a matter of buying a fixed gear for the rear hub?
