1 - 7 of 7 Posts
I recently picked up a specialized p.1 in great condition for like 25$ (frame only), and I figured i'd try out some dirt jumps/pump track stuff, and I was wondering if you guys have any recommendations on converting a geared wheelset to single speed.
I found this cheap Sette conversion kit, and I was wondering if you any of you think this is a good way to go, or if there's a better way.
Oh, and the frame has horizontal dropouts, so I shouldn't need a chain tensioner right?
http://www.pricepoint.com/detail.htm?stylePkey=16777&style_id=065 SETSC7
http://www.chainreactioncycles.com/Models.aspx?ModelID=60631
^^^I'd go with this singlespeed kit instead. You get a better quality cog, choice of color, and choice of cog size which is a HUGE bonus when building a custom bike. Plus there are more spacers so you can fine-tune your chain line better, and overall the kit is just a higher quality. I've run into issues with spacer kits like the Sette one because since there is only 2 spacers, if that doesn't line the chain up then you have to start changing other things and that's not fun.
Scroll down and check out my "Which Wheels?" thread. gbosbiker gave good advice that I followed and it worked out well.
mtbmxstreet said:
why not using single speed hub?
Because that means he either already has a geared wheelset or can get it cheaper/easier than a SS-specific ones.
I would suggest against using those cheap stamped cogs. They can gouge your hub. Get something like Surly, at least.
For spacers, I just cut up some PVC pipe (must use a table saw to get a perfectly straight cut. Been riding that way on all my SS for 3 eyars with no problems. 1.5" PVC, IIRC.
1 - 7 of 7 Posts
