Yep, you aren't imagining this. The high-pivot on the Heckler will causes the suspension to stiffen when you are pedaling. On level smooth ground this is great. When you switch the granny gear while going uphill this trait is actually magnified some, that means that when you go over a bump your pedaling forces are trying to keep the suspension from moving, and of course bumps try to make the suspension move. This leads to a much harsher ride and makes it harder to keep momentum/maintain traction. One of the big problems here is that it's hard to design a single-pivot bike to do well in all the gear-ranges that will be encountered. For a freeride or DH bike that will only have one ring up front it is much easier to design a "good compramise", but with a bike that shifts between different front rings, it is harder. The other aspect that you may be feeling is "squat", although this too would depend on what gear you are in. On steep uphills, one of my bikes tends to "squat" through it's travel when I'm trying to pedal in the middle ring. In the granny ring it does not do this as much. It basically starts to feel like a wet-sponge when I start headnig up steep stuff in the middle ring. It basically sucks a lot more energy than it would if it were on level ground. This has to do with how the contact patch relative to the acceleration force relates. This is another area where something like the Maestro or DW link should do better than a single pivot.DTL said:
As I said before though, single pivots aren't all bad. There are single-pivots without those excessive traits, although something like the Giant Meastro or DW Link is still going to be able to perform better. There are inherent limitations of single-pivot bikes, moreso with bikes that have to run more than one ring up front.
