Well guys, got the Intense 6.6 built up. Time to do some seat testing. This is going to be interesting. There are some differences between the build on the two bikes that will have impacts on things like handling and ride, so I want to start this off by saying, this is not about which is a better bike.
As far as I am concerned they are BOTH awesome bikes, but they are two different takes on the same approach. How do you build an effective full on heavy duty trailbike that is both light enough to climb anything and heavy/stout enough to keep a line in the knarliest of downhill runs?
Foes has embraced the Single Pivot Platform Shock design. It's a simple design and has the advantage of perhaps having more stiffness in the rear end. Some people who own Intense 6.6 bikes have noted a hint of rear triangle shift/flex. It's something I'll be very sensitive to. Having ridden Foes for many years, the stiffness of the rear end is something I've grown to really appreciate.
Intense has taken the approach of providing a little more usable travel and implemented the highly acclaimed Virtual Pivot Point linkage to keep the bike planted on climbs. It should allow a wider range of adjustment on the platform to provide a little more active ride. At least that's what I'm anticipating.
My first spin around the block on asphalt has revealed some hints of a difference. The 6.6 feels a little more active than the FXR but at the same time a little harsher when it comes to the ride quality. All of this is so preliminary because I haven't adjusted the shock at all, so please take that comment with a grain of healthy sckepticism.
However, my gut feel is that the new Air Curnutt has so much volume in the shock at low pressure it is able to react quicker to road cracks and the other little road irregularities that would activate the suspension. It feels a little softer. That's what I've been trying to relate to folks in my other posts. The new Air Curnutt really does have wonderfull small bump compliance while still maintaining the platform of all platforms. Hopefully, I'll be able to adjust the Fox DHX Air to match the Curnutt.
Now to some technical details. Both bikes came in right at 32lbs, so weight will not have an impact here. They both have Magura Wotans on the front end so the fork isn't an issue unless it doesn't play nice with the shock, which I don't anticipate. The Intense is riding on 2.5" WTB Wierwolf's which will slow down the steering. The FXR is riding 2.3" Conti Verts.
This point is interesting, because the FXR didn't seem to handle the Wierwolfs well at all. The steering felt like crap compared to the 2.3 Verts. That's one reason I switched them. The other issue was the rear tire rubbed pretty good at times when really railing it. Bottomline is the Foes FXR is more geared to running 2.3" rubber than 2.5" rubber.
Conversely, the Intense seems to handle the Wierwolf's fairly well. Again, my only reference at this point is some street riding, but looking at clearances and such, Intense definetly has 2.5" rubber in mind for the 6.6.
Brakes on the FXR are Hope M4's...some of the best out there in my book. The 6.6 got hooked up with what I had laying around. I wanted to do XT four pots both front and rear but the Magura only takes post mount so the ISO XT front had to be replaced by a Hayes Mag. I think braking will be decent though and shouldn't have a big impact.
Both are using SRAM 11-34 Cassettes and chain, with XO Shifting, XO rear D and Shimano Front D. Both have XTR Cranks, so transmission should be identical. I guess other than tires and the shock, they are about as close as I could get them.
Let's have some fun!!!
