AZmtncycler said:
Sorry man, didn't mean to kill your new bike stoke ...
Really?
Pic is the maiden voyage this afternoon getting ready to drop into Upper Cheesegrater.
Wanted to get in a quick loop today just to get a feel for the bike. From 40th/Shea, 100 to 1A to Irregular, HAB up Upper Hairball, then down Upper and Lower Cheesegrater and back around to the truck.
All the usual caveats apply: It was kinda hot, I haven't been on a pedal (ie, non-shuttle) ride in three weeks, I'm on vacation and drinking too much, the leftover pizza I had for lunch was fomenting revolution in my stomach, ad infinitum ...
The first ride went well. I built this to be relatively light and pedal-able. Turned out to be about the same weight as my El Guapo (32-ish pounds) which is fine. I short-shocked this build, running an 8.5x2.5 RP23 instead of the spec'd 8.75x2.75 shock. This reduces the travel down to about 6.8 or so, slightly steepens the HA (to 65ish) and lowers the BB to about 14.1 or so unsagged.
In this configuration, the bike seems to ride down in its travel a bit more than I'd like. I'll probably need to experiment with air setting or, God help me, use Pro-pedal. There is some feedback climbing in the granny ring, but nothing that held me up. I think if you're a person who really turns perfect circles while spinning, it would drive you crazy. For a hack like me, I notice it but it's not a bother..
This thing just kills it on the downs. I way overcooked the first few switchbacks on Upper Cheese not realizing what a rocket this is. I found I didn't have to hang back so far; biasing my weight toward the middle seemed more effective. Also, the bike seems to like a lot of rear-wheel input; like force-skidding into a line. It rewards good braking technique, which will be a learning experience for me.
Pleased so far. I think it'll be a fun rig. Even if it doesn't have enough pivots ...
