Hey all Pug lovers...
I'm back from my 2nd Simpson Desert Bike Challenge and I need some advice/help.
Both times I've run with my Ibis Mojo SL with different tyres and 28mm wide rims.
Now before you regail me with how I SHOULD have ridden a Pug'... hear me out.
1st... go to: www.desertchallenge.org/race_details.html ... it will tell you a little about the event.
It's a ride (race?) across the Simpson Desert in Australia. two stages per day. 80klm each morning, 50klm each afternoon. For 4 days, The 5th and last day is 80klm morning only. (but hey... you finish the stage at the Birdsville Hotel) Crossing many many sand dunes. Some are smaller and somewhat ridable... some are damn huge and very very soft.
The problem comes in the sections between the dunes. Sometimes the terrain is corrogated and hard. Sometimes it's corrogated and hard... and covered in 4-8" of very soft sand. Sometimes when running parralel to the dunes (between them)... you get long stretches of soft deep sand. Sometimes it's hard saltlake/claypans...
All these variables lead me to use the Mojo with 2.5" wide tyres in 2008 and 2.2" wide ravens (run very soft) this year.
Last year... it worked ok. I was able to ride the sand... mostly... (well... ok... a little...)
This year... oh dear... the sand was soft, Very very soft... and I did much walking. Much to the horror of my legs. I can ride for days no problem. But walking is bad for me...
My questions are this:
a) How much floatation does the Endomorph have on very soft, hot sand at max inflation? I mean... could I run it 'hard" (you know... Endomorph hard... soft by any other tyres standards)... and still ride on top of the sand? Or will I need to run the tyres soft(ish) to get decent floatation?
b) how much drag does the Endomorph have on hardack? This year I pumped my Ravens up from 15psi to 30+ when I hit a 30klm stretch of salt-lake...
c) anyone running Large Marges and Endomorphs tubeless? (anyone NOT running Stan's in the desert this year got punctures from the thorns)
I guess I'm trying to balance the drag of the larger tyres v's the advantages of floatation over the sand...
I feel that if I can stay on the bike riding... I'm mentally better off. if I have to walk... then I get very negative. Then my speed drops. Once you get below 12.5 kph... the sweep 4wd picks you up...
Help appreciated.
And before someone says the obvious... "build one up"... I'd like some honest feedback 1st.
Thanks in advance guys.
Elvis.
Help appreciated.
Elvis.
