1 - 3 of 3 Posts
I've got an Alfine on my pugsley with maybe 100 miles on it. I've noticed lately that there is some side to side play in the wheel. Is there an adjustment I can make or is this normal? I was just going through the tear down procedure of how you just take the two nuts off the non-drive side but I don't see this part actually wiggling when I pull the wheel side to side.
any ideas?
Yep, it's the cones. You'll need a 15mm cone wrench, 17mm normal or cone wrench, and a shifter (for the flat bits of the main shaft), as well as a centrelock tool. It's an easy adjustment - just take off the disc rotor and you'll see the cones. :thumbsup:
PS don't over-tighten them.
1 - 3 of 3 Posts
