I have put this here and in the suspension forum, sorry for the duplicate post...bought a shock and the S/N pulls the product up as Model ID:FS-SIDS-BNSE-C1.
Great right? except I cant find any info on that fork...also there isn't any tiuning info for it on the website or the RockShox app. Its a SiD SL, with a BRAIN damper. I think its a takoeoff from a Stumpjumper? Its not the SiD SL Ultimate BRAIN, and its not any of the other models...maybe its a lower end SiD BRAIN fork for OEM? A SiD SL Select with a BRAIN damper put in? The Ultimate has the Carbon bits to make it even lighter...so maybe its the aluminum body with the BRAIN damper? If thats what it is..should I tune it like the SiD Ultimate BRAIN because the only difference should be the slightly lower weight?
Here is what the RockShox site says...Note the tuning tab is greyed out.
