I am setting up a pair of DT XR331 and Schwalbe Thunderburt with DT rim tapes. This is the 1st time I am doing tubeless.
I seated the beads on the rear first and pumped it up without any sealant. it took about 12h to get to 15 psi from 30psi. Is this OK?
But I am having trouble with the front (still no sealant yet). After I pumped it up, the pressure dropped quickly and was almost gone in 2 hrs. I can hear a very slight hiss from the valve, which is hand-tightened hard. it probably came from a small slit on the tape at the valve hole.
There's a few things I don't quite understand. Why does the valve hole have to be covered with tape and then cut open? I thought the rubber grommet on the valve will seal well against the aluminum edge of the rim hole if it is clean and flush. With the tape, if it folds and is creased at the hole, doesn't it make the rubber grommet harder to fully cover the hole edge?
And how well should this set holding air without sealant? I've heard quite some combos hold air very long w/o sealant.
Or maybe I should get better valves? Are valves with the U-shaped grommet better than conical grommets?
