1 - 6 of 6 Posts
rth009
I cleaned and greased my DT 350 hub a few weeks ago. When I opened it up, I saw that the edge of the freehub body looked like this. I cleaned and greased it, and put it back together, and it works fine, but I'm wondering if I shouldl get a new freehub body. Note the "teeth" on the edge. Thoughts?
1945585
1945586
rth009
Discussion Starter · #2 ·
And if I need to replace the freehub body, and I will to ensure this hub doesn't fail and put this bike out of commission, can I get any DT 350 freehub body with an XD driver? The hub is a 150mm DH hub but Im using it on a Superboost 157 bike with SRAM cassettes.
Thanks in advance for the advice.
No it should not look like that. It appears it has been damaged. Assuming DT will not warranty that, I would clean up the edge and remove any of the metal chips and keep running it. The internal splines used to retain the star ratchet appear to be fine but you don't want to be grinding chips while riding as that will just wear out the rotating elements much faster.
Contact DT Swiss and show them the pics. It could be a machining defect from the factory.
rth009
Discussion Starter · #6 ·
I purchased this second hand and its pretty old. I don't think it owes me anything so I'll just get a new one.
Thanks, all.
1 - 6 of 6 Posts
