Yawn....
Grumpy said:
You missed the point, what you paid for a couple tires you bought at one time cannot be logically extended to infer that UST's are much more expensive. More importantly it is not true.
It is widely accepted (not just my opinion) that UST tires do roll better and do have better traction and are more reliable. In addition the current crop of lightweight USTs are actually lighter than a tire (the same tire) with a (reasonable 150-180g) tube.
BTW you do get that the yestubes site is a rip on Stan not UST's don't you?
So switching from tubed tires to UST isn't expensive? I thought at a minimum you had to buy a UST rim.
It's not widely accepted. People who ride them contend this based on what marketing has told them. The only "study" conducted to date is from a European MTB mag. The article (from which all the marketing claims have been based) claimed less rolling resistence, better traction, yada, yada, yada. One article in a mag and UST system manufacturers jumped on this and began promoting it. The only problem is that the author of the article happened to be the project engineer for Michellin who was in charge of the UST mountain bike program. Perhaps a conflict of interest?
In laboratories on an absolutely smooth surface, tubeless rolls better than tubed. The problem with this study is that mountain bikes rarely ride on a laboratory smooth surface.
You can post until you're blue in the face but I have two bikes that I ride frequently. One with UST tubeless and one tubed.
- The difference in air pressure? Zero.
- Number of pinch flats on both systems? Zero.
- Traction and grip on both systems? I can't tell the difference.
- Number of tire brands/types I've switched to on tubed trying to improve traction and performance in the past 4 years? Zero.
- Number of tire brands/types I've switched to on tubeless trying to improve traction and performance in the past 4 years? 3 just to match the performance of my tubed tires.
- Amount of time spent dicking around with sealant/holes in the tire/low air pressure on tubed? Not much.
- Amount of time spent dicking around with sealant/holes in the tire/low air pressure on tubeless? Every ride.
BTW: The Yes Tubes site is a rip on tubeless, not just Stan's. Pete and Rich set it up to bag on people who bought in to the tubeless hype. But you knew that, I suppose.
When you switched to UST, did you go up in tire size or stay the same?
Ken
