adaml said:
Thanks for the replies. I wanted the pedros set but didn't want to spend the money, so I was looking for some reason to buy or not buy from the post. I pretty much know what tools I need for my bikes, but wanted a little more so I do have it if needed. I considered the spin doctor set because of the value but I get extremely pissed if a wrench gets soft on me. I'll probably get the park ak-32 set. If I were to get all of the Park tools individualy that I need/want I would come out about the same price so I'll get the set with some extra tools for free. They are going for about $180 all day on ebay.
That is a really good kit to start with. A couple of more things to buy separately that are good to have:
-a set of metric allen keys, the 3-way hex keys are one of my favourite tools BUT they will not get into all of the tight places (FD clamp on FS, FS pivots, etc).
-a sharp awl, used to open up the liner inside shifter or brake cable housing after you cut the housing.
-an external BB tool if desired, you can now get a socket style to be used with a torque wrench. Most people just use the wrench style BB tool for external BB's.
-an old Shimano steel rear wheel skewer (like the ones you get with trainers), use this to go through the rear hub/BB axle to hold the cassette lockring tool/BB tool in place, it will make the job much easier and reduce any wear on the splines of these tools.
-3/8" drive TORX bit socket set down to T-25, used for removing disc rotors and a few other odd places.
- a 10 mm hex key (covered below), used remove freehubs off of Shimano hubs.
- a 3/8" metric Hex key set that ranges from 4 mm to 10 mm, to be used with torque wrench.
- a 3/8" drive torque wrench which is capable or measuring torque in both left and right hand threaded applications. The one below is nice as it goes low enough to cover rotor bolts, stems bolts, and suspension bolts. It will not cover BB or crank arm bolts though.
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00944560000&subcat=Torque+Wrenches
- a Parktool DAG-1, derailleur hanger alignment gauge.
