I am building a Ibis Mojo 3. It is my first custom bike build. I purchased a new set of Ibis S35 aluminum wheels with Ibis Logo hubs new from an online retailer.
The rear hub is 152 mm wide. The distance between the thru bolt holes on the rear swing arm is 152 mm. The derailleur hangar is 4mm.
The right side of the hub slots into the derailleur hangar which adds 4mm to the width of the hub.
If the hub was actually 148 mm wide it would be a perfect fit. At its current width of 152mm it won't fit with the derailleur hangar attached.
Is it possible that the hub was incorrectly assembled with incorrect end caps?
