Also if you switch pads or pad type should you change the rotor also, due to different materials bedded into the rotor from previous pads?
Thank you.
Thank you.
I used and always use automotive brake cleaner and wet 1000 grit sand paper, the black or dark grey if I remember last time.For the same pads, increasing the rotor diameter increase the braking power for the same pressure at the lever (the limit being the tire grip) and also decrease the functioning temperature.
Metallic pads tend to resist the heat better, actually they transfer the heat to the caliper and bite stronger when warm. They might be more noisy and need to reach a certain temperature to have the maximum performance.
Organic pads have a strong initial bite when cold but fade faster when becoming hot. They are silent but don't last long in wet/mud conditions.
In the end it depends on your riding conditions, if you are gravity oriented big discs and metallic pads might be the best choice but for instance I swap to organic pads for all mountain in winter unless it is very wet.
No need to change the discs if you change the pad compound, just clean the discs really well with something like isopropyl alcool and if you want to be perfectionist you can even send them very lightly with fine sandpaper (>1000 or so)
With the same disc and same pad I suspect the code RSC to have more power than the G2.
And don't underestimate the effect of a good bleeding, pretty sure a properly bled G2 will work better than a RSC without maintenance.
I have tried the trickstuff POWER pads on my Code RSC. The power increase is real but they lasted me 4 days in the Alps so I went back to the classic metallic pads.I used and always use automotive brake cleaner and wet 1000 grit sand paper, the black or dark grey if I remember last time.
experince with the new SRAM POWER PADS?
There's a noticeable improvement from Guides to G2. Unless you're riding some actual DH/enduro race course type terrain I'd probably stick with the G2 but upgrade both rotors to 200mm.I have 2017 guide RSC on 180mm rotors now and they are just meh/not great.
New bike is coming with G2 RSC And 180mm rotors.
So is the new G2 and whatever OEM pads noticeably better than my 2017 Guides with new sintered SRAM pads?
i have a 200mm rotor to put up front. Is the 200mm rotor a better upgrade than G2 to CODES?
Wondering if I should have them change to CODE RSC, and save some money vs possibly decide later to chang, and pay full price later for CODES.
THANK YO.
