Juicy 7's don't use cables. They use hoses.
Everything you need except a razor blade and a piece of paper towel comes in the bleed kit.IRONMAN1518 said:There is a video showing how to do it @also @ the Avid website there is info. You'll need a new "olive" and the "hose barb" and a couple of tools like a #10 Torx wrench to install the new hose barb. You'll need to bleed the brake after it is all done. Juicy 7's are difficult to bleed without the proper bleed kit.
There is a video here showing how to do it.You really need the fittings that screw into the master cylinder. Good luck with all that!
