this was posted in the drivetrain forum, but when nobody responded, I figured my questions might get a better response here...
My new chain (installed at LBS) is way longer than necessary. I would like to get it shortened to the point where I can run big/big without damaging anything AND have a spare link or two in case of problems on the trail. That would mean taking out like 8-10 links, I think.
Question 1: Does using a chain breaker hurt the strength of the chain? I used a chain breaker on my old chain and in its final day it blew apart 4 times (although that old chain had other issues as well that may have stressed it out)! Any advice?
Question 2: Is there some kind of rule for the chain tension "preload" screw (I don't know what else to call it) as you shorten a chain? I assume I should just turn it in enough to keep the tensioner from doubling over completely when I am in little/little. Is it more complicated than that?
Thanks for any advice!
