A couple days ago, I posted a question about offset shock hardware and recommended manufacturers. After checking the clearance, it looks like only one eyelet on the shock has enough clearance to fit offset hardware, for a modest 2mm shortening.
This will come up short of what I'm hoping to achieve in order to lower & slacken the bike for my son, who will run 155 or 160 mm cranks. Which leads me to the next question. What are my options for a shorter shock?
1) Retrofit an air can intended for a 152x32mm Fox shock. Every way I think about it this will work, shortening the shock by 6.XXmm (.25"), effectively turning it into a 158x32mm shock, with the leverage ratio it will reduce travel by 15mm. I'm OK with the travel reduction to optimize geometry. I'd combine with one offset shock hardware (front eyelet), for a total of 8 shorter effective shock length. It looks like the added length vs. the 152mm shock would be in the length of the damper body extended out from the air can. Frame clearance is good all around. Looking at shock cross-sections, seems like there wouldn't be any issues from a shock perspective either.
Is there any reason shortening travel with just an air can won't work?
2) Purchase a 152x32mm shock. These are hard to find, it looks like the only manufacturer that even intends to make one again is Manitou (Mara). Although I'd prefer the additional BB drop associated with this option, there aren't any available for sale, and I can't find any on the used 152mm shocks. Even if the Mara was available, I'd be looking at $350 more than just retrofitting a shorter air can to the existing shock. This would lower the rear about 29mm, so about 20mm at the BB, which would be perfect. Frame/tire clearance is plenty for shorter shock length at full compression.
Does anybody know where to find a decent 152mm x 32mm shock that won't break the bank?
Thanks, looking for answers to the questions above, other options.
