I've been wondering why people use short stems???
I'm sure that this has a lot more to do with a persons body proportions.
but I'm going to post it anyways.
I originally set my ML up with a 90mm. but that was auto pilot. everybody I ride with has a short stem.... seems like that was always the first modification. Buy a giant VT or Marin or whatever line bike... put a short stem on it and DH tires maybe an 8 inch rotor and then you are ready to rock and roll. Seemed that these bikes always had a forward weight bias and I needed the short stem to be able to get behind the seat easy.
but I was having "trouble" getting bite with my front tire on my ML. just seemed to get loose on me from time to time when trying to rail a corner.
so I called titus. I was told that I was the first to complain. but we talked a bit. the guy said that the ML was designed with a rearward
weight bias and that I should try to shift my weight forward a bit when I corner. after concentrating on the issue... I discovered that I could deliberately move my weight forward and rail corners with plenty of grip.. and that if I was taking a corner standing, I already did that, but if I was pedaling thru a corner I was more likely to wash out. So I
just started sliding my but forward on the saddle for a corner. But I felt to far forward in this position when I had to pull hard on the brakes.
so I bucked my conventional wisdom and got a 110mm stem. feels great. best thing I ever put on it. my ML actually even goes down hill better with the longer stem. the turning feels more instinctive and natural, plus my braking body position is in the same position as my turning position. and I still don't have any issue getting behind the seat. Nor do I even feel close to endo.
So armed with my new observations, I talked with one of my buddies that is a much better DH rider then me. turns out he just doesn't care what the bike handles like. he is going to shift his weight around to make the bike turn and needs a short stem so he can do the vertical rollers and drop ins.
this weekend I was pre-running the downieville XC course.. which has some long mild technical mild DH. I concentrated on staying in the attack position instead of getting behind the bike. I've probably been getting behind the bike to early all along anyway... it does take some balls to stay on top of the bike going down rocky hills, but I feel like
my commitment to stay in attack position really improved my riding experience. And motolite ecstasy.
So back to the point, the Titus guy told me that they designed the ML with a rearward bias to begin with.
So, maybe for trail biking a "short stem setup" trick works on bikes that started out with a frontward bias.
so why do you like short stems??
